TwinTurbo.NET: Nissan 300ZX forum - JDM engine - brake booster connection.
Doug71zt(CAN)
on April 08, 2019 at 4:32 PM
Found Vacuum Leak - doesn't look factory, what is this?
posted by nissubaru
on April 08, 2019 at 04:19 PM
You can replace it with a BSPT plug. You may have to source one from a junkyard or another USDM plenum.
As for the wiring, is you car Cali spec, 96 or has the engine harness been replaced?
Those look to be EGR temperature sense and something else.
nissubaru
16:19:41 04/08/19
Re: Found Vacuum Leak - doesn't look factory, what is this?
ZBOOSTT
16:30:46 04/08/19
ZBOOSTT
16:30:50 04/08/19
Thanks I'll try to find a new bolt first, if not I'll plug i (n/m)
nissubaru
16:47:18 04/08/19
JDM engine - brake booster connection. -
Doug71zt(CAN)
16:32:12 04/08/19
Supposedly a new wiring harness a few years back.
nissubaru
16:46:20 04/08/19
Re: Supposedly a new wiring harness a few years back.
ZBOOSTT
18:05:55 04/08/19
ZBOOSTT
16:38:18 04/08/19
Update: Fixed this with a ZSpec Rear Plenum Bolt/Plug
nissubaru
09:08:08 04/15/19
